How to enable surface evaporation
Old   October 8, 2004, 14:54
Default How to enable surface evaporation
Vijayaraj.B
I' m working to simulate a drying of biomass product whih has a very high moisture content. For this I m using Speciecs model in Fluent.I have selected abosulute pressure.The bottom plate is heated to a higher temperature..Above the biomass layer hot air at a temperature of 100'C is made to flow at a velocity of 1m/sec.I have defined 4 species in the problem,ie Air,LiquidWater, waterVapour and Biomass. Since it is a drying problem the moisture present in the biomass should be evaporated and is to be carried along the air which is flowing over the biomass layer.Hence the relative humidity of the air should increase.But when I run the above said problem,evaporation of the liquid does not take place .Hence to activate the evaporation of fluid from the biomass to the air what should I do. Kindly send me your suggestiions.
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 12:12
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 12:05
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 03:09
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 13:43
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
