October 6, 2004, 03:12 |
A problem in dynamic mesh
Hello
I have really a big problem .I need to active "spring based smoothing" in dynamic mesh options ,but it dos'nt work .If some one help me to solve this problem it would be grate. Thank you for your time . SVH ps: please please help me I'm in a hurry. |
October 12, 2004, 08:46 |
Re: A problem in dynamic mesh
can you discribe your problem in detail ?
October 12, 2004, 12:50 |
Hello kim
Thank you very much for your response.I'm using dynamic mesh to make an oscillating pipe ,the wall is defined as a rigid body ,the cells are hexahedral ,and I have used symmetry BC. In previewing the motion just the wall moves and fluid interior cells get deformated and it creates negative volumes. I have used bellow command to turn on the Spring-Based Smoothing method: > (rpsetvar 'dynamesh/spring/all-element-type? #t) dynamesh/spring/all-element-type? > but nothing changed. Maybe the settings that I put in dynamic parameters panel aren't correct. Thank you in advance. SVH |
Dynamic mesh update problem. | David | FLUENT | 3 | March 15, 2012 05:02 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
Dynamic Mesh problem | Paul_321 | FLUENT | 11 | August 11, 2009 11:32 |
CFD-3D flow problem using Dynamic mesh method. | Sar_mech | FLUENT | 1 | November 27, 2008 21:17 |
Dynamic mesh problem | Sampath | FLUENT | 1 | October 13, 2004 06:44 |
