Importing files from Pro/E to Gambit
Old   October 5, 2004, 05:28
Default Importing files from Pro/E to Gambit
Kiran
Hi, How do I import a geometry created in pro/E to Gambit, so that I can mesh it properly and solve it in Fluent? Thanks, -Kiran
Default Re: Importing files from Pro/E to Gambit
Kiran
Old   October 5, 2004, 09:02
Jason
I recommend exporting a step file from Pro/E. Gambit has an import function for step files. For external flows, I recommend creating your control volume from the geometry in Pro/E instead of Gambit. It will save you a lot of heartaches. I've had better luck creating the control volume in gambit for internal flows, but I still have to go back to Pro sometimes.
Goodluck, Jason
Old   October 5, 2004, 17:00
frank
go to file->import->gemoetry->proE.
if you do not have the correct version of proe it will not work. in this case you can save the proe file as a step file and import a step file as a 3d solid.
frank
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 08:21
Importing files to GAMBIT Carlos Ruiz FLUENT 2 January 16, 2009 13:29
Importing IGES files into GAMBIT and meshing kartik FLUENT 3 September 23, 2008 01:12
Importing DXF files into PHOENICS 3.5.1 Alejandro Valenzuela Phoenics 5 October 17, 2007 01:31
Importing and cleaning STL files Peter FLUENT 2 October 13, 2006 06:41
