Drop velocity ??? help me !! -.-
Old   October 3, 2004, 22:52
Default Drop velocity ??? help me !! -.-
Jay
Hi...
I am testing the model that the liquid is falling down on the surface.
VOF - 2 Phases (air, water) - Geo reconstruction - unsteady
And I made the volume fraction for the liquid.
:> adapt - region - circle
:> initilize - patch
I would like to put the velocity condition, 1.6m/s, for the liquid.
But, I dont know how to put the initial velocity for the liquid.
Should I use the UDF ? Is there any good way to solve the problem, not using UDF?
Please, help me. Thanks for your attention
Jay
Old   October 5, 2004, 00:45
Default Re: Drop velocity ??? help me !! -.-
Aravind
hi Jay,
When you patch the region, there is an option where you can specify the initial pressure, velocities and temperature(if you have enabled the energy equation! just like you patch region for volume fraction by choosing 1 for water, you can specify velocity, pressure etc by choosing mixture! and since you are simulating water dropping, dont forget to enable gravity! hope this helps.
Aravind
Old   October 5, 2004, 01:19
Default ^^;; Thanks
Jay
Hi Aravind
I found the way you just told me.
Thanks for your attention.
Have a nice day..
Jay
UDF error - parabolic velocity profile - 3D turbine Zaqie Fluent UDF and Scheme Programming 9 June 25, 2016 20:08
help with UDF for contact angle based on contact line velocity gandesk Fluent UDF and Scheme Programming 14 October 29, 2012 14:58
how to compute relative velocity from absolute? spk Main CFD Forum 3 July 9, 2010 09:42
Pressure Drop in terms of velocity Arun FLUENT 0 June 26, 2008 08:45
Relationship between velocity and pressure drop harry Main CFD Forum 13 May 8, 2007 07:39
