Gambit error: Cannot find exceed x server
Old   October 3, 2004, 18:09
Default Gambit error: Cannot find exceed x server
Jake
I have installed Exceed 7.1 and Gambit 2.0 on my PC operating with WinXP. This error message appears whenever I tries to run gambit "Unable to Find Exceed XServer" or "Unable to open display".
Tried using the following workaround posted in Hummingbird website but the same error still persists.
Open up Control Panel Double click on System Click on the Advanced tab Click on the Environment Variables button Under User Variables click the New button In the Variable text box type: DISPLAY In the Value text box type: computer_name:0.0 (where computer_name is the actual name of your computer) Click OK.
Any advice how to resolve this?
Thank you.
Old   October 3, 2004, 20:17
Default Re: Gambit error: Cannot find exceed x server
sam
install complete verson of exceed with selceting complete ans also make it common
Old   October 4, 2004, 03:46
venu gopal
You just install the exceed again, and give personal installation or complete installation. Then it will work. And if you have gambit 2.0.4 version, install it. It will not give any problem with exceed 7.11 version. I hope it will work
Old   October 4, 2004, 09:59
Jake
Tried re-installing exceed and gambit but still didn't work...
Thanks for the advice though
Old   October 4, 2004, 10:38
sam
it should work
did u set envirment variable
Old   October 4, 2004, 12:41
venu gopal
Try with gambit 2.0.4 version. And give the license path correctly.
Venu Gopal
Old   September 10, 2011, 12:43
jbr
jonbonraki is on a distinguished road
hi all i have the following error while trying to open the gambit, can u please tell me hoe do i fix it.
gambit XIO: fatal IO error 0 (Winsock Error) on X server JONBONRAKI-PC:0.0
after 0 requests (0 known processed) with 0 events remaining.
jonbonraki is offline   Reply With Quote
Fluent 6.3 / Gambit 2.3.16 / Exceed 11 problem on Win7 pdilly FLUENT 23 April 2, 2016 13:10
Gambit Default Working Directory Virgil Howardson FLUENT 5 December 19, 2009 07:13
Athlon 64 Gambit Compatibility? Derick FLUENT 3 January 17, 2006 18:28
exceed for gambit 2.2 steve FLUENT 4 July 26, 2005 10:09
Gambit error : Unable to find Exceed X Server Jarod FLUENT 2 November 4, 2004 07:41
