September 29, 2004, 10:32 |
Coriolis force
Hi, I used FLUENT to simulate the water into sink. Could FLUENT simulate the Coriolis force??
September 29, 2004, 11:34 |
Re: Coriolis force
coriolis forces are invloved in rotating reference frame and fluent does simulate these forces
September 29, 2004, 15:35 |
Re: Coriolis force
Hi
But cariolis forces dose not make much effect in sink as scale level are very small. The way the water goes down into the sink depends on initial presence of eddies or turbulence. Acc. to me it may go down clockwise or anticlockwise. Cariolis force comes when there are large scale such as oceans, atmosphere winds, etc. Regards, Titiksh |
September 29, 2004, 20:11 |
Re: Coriolis force
I do believe there is a difference based on Coriolis forces. When you flush a toilet, the direction is dependent on the hemisphere. I believe you will have the same situation for sinks. Am I incorrect?
September 30, 2004, 06:35 |
Re: Coriolis force
Hi Chetan,
Ya, I think its been practiced all round the world, but still I am not sure whether the theory goes right in the flushing. Regards, Titiksh |
September 30, 2004, 16:56 |
Re: Coriolis force
The direction the toilet flushes depends entirely on the way the stream is forced out. It is forced out at an angle to give a swirl. The coriolis effect on toilet flushing is an urban myth.
Coriolis effect only applies to large scale observations. Over time, the right rail in the (Northern Hemisphere) of a train track gets worn down faster, and the right side of river beds is deeper. But small things like water going down a drain, are not effected in any measurability by the Coriolis effect. |
coriolis force in MRFSimpleFoam | renyun0511 | OpenFOAM Running, Solving & CFD | 2 | October 28, 2013 08:27 |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 23:03 |
User-defined force transfer across FSI interface | vivekcfd | CFX | 7 | March 10, 2010 21:43 |
DEFINE_CG_MOTION and pressure force | Teo Fumagalli | FLUENT | 0 | April 11, 2008 11:25 |
MRFZonesC questions what is the mesh_V and why only Coriolis force no centrifugal force | waynezw0618 | OpenFOAM Running, Solving & CFD | 49 | April 8, 2008 05:23 |
