How can I active spring Based Smoothing??
Old   September 26, 2004, 15:13
Default How can I active spring Based Smoothing??
svh
I'm using dynamic mesh to make a moving pipe ,the wall is defined as a rigid body ,the cells are hexahedral ,and I have used symmetry BC.
In previewing the motion just the wall moves and fluid interior cells get deformated and it creates negative volumes. I have used bellow command to turn on the Spring-Based Smoothing method:
> (rpsetvar 'dynamesh/spring/all-element-type? #t)
but nothing changed. Maybe the settings that I put in dynamic parameters panel aren't correct , please please help me to solve this problem.
Thank you for your time.
svh
Spring smoothing Arne FLUENT 0 October 29, 2007 15:06
arc based TFI smoothing? zonexo Main CFD Forum 0 August 20, 2006 23:00
Hexa smoothing (ICEM CFD 10.0) CFDworker CFX 3 November 2, 2005 11:23
Help me to active Spring Based Smoothing!!! Atefeh FLUENT 0 September 29, 2004 16:32
How to active "Spring-Based Smoothing "? svh FLUENT 0 September 22, 2004 09:19
