Group injection distribution
Old   September 24, 2004, 08:57
Default Group injection distribution
David
I am doing a combustion simulation in a gas turbine combustor. I have tried the 2D coal.cas tutorial which uses a Rosin-Rammler distribution. But when I check the diameter distribution, it shows an flat, even distribution. Also when I implemented the group injection in my 3D case, it shows the same instead of a Rosin-Rammler distribution.
Why is this?
thanks for the time taken in replying
Regards
David
Old   September 24, 2004, 10:16
Default Re: Group injection distribution
Titiksh Patel
Hi
It should work. Try it again and take care you have given all details in Injection Panel: Location, mean dia, spread parameter, etc.
Titiksh
Old   September 28, 2004, 08:06
David
thanks for your response.
but no it's not working, I have tried times and again and the results keep changing even though i put the same data.
Does anyone have any idea of what is wrong in my case?
thanks
Regards
David
Old   October 14, 2004, 21:01
rivers
hmm...hard to say. www.uscomco.org/t/
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
Are my IRIXbs systune parametersb setting correct lakeat OpenFOAM Installation 1 May 5, 2008 11:48
DPM injection with RR distribution dan FLUENT 2 November 1, 2005 10:29
BFC for Dam break problem Mehdi BEN ELHADJ Phoenics 0 January 18, 2001 16:22
