Gambit + exceed + XP
Old   September 23, 2004, 07:12
Default Gambit + exceed + XP
pkt
Hei,
I am trying to run Gambit 2.0.4 on winXP . I install exceed 7.0 ; When I run gambit.exe I have this error :
Cannot open connect stream. TRANS(SocketINETGetAddr): tnamebysocket() failed TRANS(SocketINETConnect): TRANS(SocketINETGetAddr) () failed TRANS(Open): transport open failed for tcp/LOCALPC:0 Unable to open display
Do I need to do smthg with exceed of not ?
Thanks PKT
Old   September 23, 2004, 09:16
Default Re: Gambit + exceed + XP
Gambit User
Give Fluent a call they should be able to sort the problem out. You'll need to quote you license No.!
Old   September 23, 2004, 10:52
pkt
hei I solve this pb : is was a DISPLAY variable which has to be set to the name of the computer. Now when I run gambit with gambit -new I have this (a sesseion of exceed is open): Warning: locale not supported by Xlib, locale set to C Warning: X locale modifiers not supported, using default
Using X_DEVICE_DRIVER with standard visual. Received X Intrinsics Warning <translation table syntax error: Unknown keysym name: osfActivate>. Received X Intrinsics Warning <... found while parsing ':<Key>osfActivate: PrimitiveParentActivate()'>. ................. followed big a long list of same warning , then this: ................. ERROR(TuConvert) Conversion of 'windows_user2.xpm:String' to 'Pixmap' failed ERROR(TuConvert) Conversion of 'sash_delta.xbm:String' to 'Pixmap' failed ERROR(TuConvert) Conversion of 'windows_user1.xpm:String' to 'Pixmap' failed ERROR(TuConvert) ................... which ended up by this :
FATAL ERROR: Could not initialize ACIS.
Is anybody know where this come from ?
Thanks
Pascal
Old   September 24, 2004, 01:52
Blorg
My suggestion is to be patient, Gambit is - as the name implies - a roll of the dice. If it works it works fine, but it might just as well give you gray hairs. It is a classical example of the save-or-cry rule.
Call Fluent support about your particular problem.
Old   September 24, 2004, 07:15
sam
wow
wat a interesting comment
:P
best of luck cfd people
Old   September 27, 2004, 10:43
frank
i have this same problem. please tell me exacly how u solved the set environment problem.
thanks frank
Old   September 28, 2004, 01:40
SAM
Install exceed again and give option as complete installation and other option to give is that it can be accesed by every one
hopes this will work
Old   April 16, 2010, 05:50
Ivan
IvanCFD is on a distinguished road
Hi Sam,
I have this problem of how to run Exceed before launch Gambit. I installed the "Typical installation" and followed all the steps as monkey without doing anything.
Now, what I want is to access my own computer to launch Gambit. I guess I have to give my computer a name or something so I can access it through Exceed and then launch Gambit, right?
Anyone knows how?
Thanks a lot beforehand.
Ivan.
IvanCFD is offline   Reply With Quote
Fluent 6.3 / Gambit 2.3.16 / Exceed 11 problem on Win7 pdilly FLUENT 23 April 2, 2016 13:10
tips for runing Gambit without Exceed in Win Vista Fabio Saltara FLUENT 9 September 23, 2011 14:59
Gambit 2.3.16, Xming or Exceed...HELP! bambam3417 FLUENT 10 May 7, 2010 13:39
Exceed in Gambit panagiotis ANSYS Meshing & Geometry 2 March 20, 2009 14:48
