September 20, 2004, 10:07 |
Recomended value for y+?
Looking for the y+ distance from the wall to the wall-adjacent cell when using the Non-Equilibrium Wall functions?
Thank you /Joe |
September 20, 2004, 21:34 |
Re: Recomended value for y+?
I would recommend between 1 and 5 for mesh adaption.
September 21, 2004, 02:01 |
I believe you have the same rules as for standard wall functions, i.e. y+ > 30. Please check Fluent manual (chapter 10 on turbulence modeling)
October 3, 2004, 10:07 |
If you use standard or non-equilibrium wall-function, you need to have 30 < y+ < 60.
Values of y+ close to 1 are required by the enhanced wall treatment, but are not acceptable for wall-functions. Hi ap |
October 3, 2004, 10:08 |
This is not valid for wall functions, but for the enhanced wall treatment.
Hi ap |
October 12, 2004, 16:28 |
Hello, ap
Why you always say Y+ is between(30,60)? As I know near 30 is ok! someone always use >11. Can you give some references? thanks |
October 12, 2004, 17:21 |
A good reference is Wilcox's book:
D. C. Wilcox. Turbulence Modeling for CFD. DCW Industries, Inc., La Canada, California, 1998. For y+ < 11.225 FLUENT uses the linear law, while it switches to the log law for greater values of y+, which, however, is proven to be valid only for y+ about in the range 30 < y+ < 60. The more you go out of this range, the worst results you should expect, but keep in mind these are empirical results (all wall functions are based on empirical results). You're right, a value around 30 is ok, it's close to the range of validity. Hi ap |
