initial conditions with transient UDF
Old   September 17, 2004, 13:30
Default initial conditions with transient UDF
Antoine Pages
Hi.
I use a transient UDF to simulate the flow around an oscillating NACA section. But the initial conditions are different each time I run a simulation (it is as if, in the function sin(2*pi*f*t), the time t was never the same at the beginning of the simulation); as a result, when I use the data of Cl and Cd registered, I never know which angle of incidence corresponds to each time step. How can I fix this problem?
Thank you for help.
Old   September 17, 2004, 14:50
Default Re: initial conditions with transient UDF
Aravind
Each time you run the problem, you NEED to initialize it, under Solve>initialize. You can also choose to initialize the problem from a Boundary, i guess in your case you need to initialize from the inlet.
Aravind
Old   September 18, 2004, 07:26
Antoine Pages
I initialize each time from the velocity inlet, but the initial values of x and y velocities (in the "solution initalization" panel) are different each time I do it. Do you know why?
Thank you.
Antoine
Old   September 18, 2004, 13:37
Aravind
Since your velocity is a function of time, I am guessing that the time is not being initialized to zero at the beginning of the simulation. That means, the UDF is not getting initialized. Can you tell me the procedure, as to how are you doing your problem? may be, if you compiled your function and did the simulation, it might work! (not sure).Hope this helps.
Old   September 19, 2004, 12:51
Antoine Pages
In fact I hadn't checked all the data I had registered and it seems to be all right just with the initialization; the velocity seems to be intialized on the time step where the previous calculation has been stopped, but then after a few time steps the velocity computed is the velocity expected. Sorry about that and thank you for help.
PS: the compilation of the program between each calculation doesn't change anything to the intialization.
alphaEqn.H in twoPhaseEulerFoam cheng1988sjtu OpenFOAM Bugs 15 May 1, 2016 17:12
Velocity blows up suddenly after 30,000+ iterations lordvon OpenFOAM Running, Solving & CFD 15 October 19, 2015 14:52
Error while running rhoPisoFoam.. nileshjrane OpenFOAM Running, Solving & CFD 8 August 26, 2010 13:50
Modeling in micron scale using icoFoam m9819348 OpenFOAM Running, Solving & CFD 7 October 27, 2007 01:36
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
