moving wall and fluid
Old   September 12, 2004, 03:08
Default moving wall and fluid
soody
Hi fluent users,
In my problem I have a moving wall that is in touch with a fluid ,I used CG_motion and defined wall as a moving zone, but I don't know what to do with the fluid, define the fluid as a moving zone(define it rigid body), or it will automatically move.
Thank you for your time.
soody
Old   September 12, 2004, 09:49
Default Re: moving wall and fluid
Neng_r
I have meet the same problem! So thanks for any help!
Old   September 12, 2004, 12:52
stk
You will let the default-interior zone (fluid) out of the dynamic mesh panel declarations. These cells will be locally remeshed AUTOMATICALLY, if you enable the local remeshing and spring smoothing (dynamic parameters). So you don;t have to do anything except from programming and hook the wall motion!
Old   September 20, 2004, 02:37
svh
Dear stk, thanks for your reply, I did that, but when I preview the motion the wall moves and it makes fluid cells deformated,and create negative volume. If possible help me to solve this problem.
thanks and regards
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 01:04
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
modelise the motion of the fluid by a moving wall samnetmoon FLUENT 1 April 21, 2008 08:06
Multicomponent fluid Andrea CFX 2 October 11, 2004 06:12
moving wall and fluid svh FLUENT 2 September 30, 2004 08:33
