Temperature Vs time Plot
Old   September 8, 2004, 15:18
Default Temperature Vs time Plot
Bikash
hi
i want to plot a temperature Vs time graph. i have all the solutions, i can find xy plot but how do i plot the temperature change with time?
i would greatly appreciate your help
thank you
bikash
Old   September 8, 2004, 21:03
Default Re: Temperature Vs time Plot
David Stanbridge
Old   September 8, 2004, 21:06
David Stanbridge
This is very simple if you have outputted the correct monitor files. I am not sure of the problem but for every time step you can "write" a load of different characteristics. Have you done this?
Dave
Old   September 10, 2004, 07:46
suailek
go to Solve-monitors-surface or volume according to what you want. you can plot temperature,pressure etc vs flow time, time step and iteration.
Old   February 4, 2017, 07:29
Default CFD Fluent
Akriti
singhal_akriti is on a distinguished road
Hi
I am doing a solid-fluid heat transfer analysis using ansys. I have a tank from which water is moving out with raised temperature. The coil inside the tank is generating heat which is transferred to the water by convection. My problem is the temperature of water is falling with increasing time. I need it to rise. What could i possibly be doing wrong?
singhal_akriti is offline   Reply With Quote
Old   February 16, 2017, 00:52
Vignesh Lakshmanan
ViLaks is on a distinguished road
Can you give more details about your problem?
ViLaks is offline   Reply With Quote
Old   February 17, 2017, 03:56
Akriti
My project involves increasing the temperature of water as it moves from inlet to outlet. The water is made to flow inside a tank which has a heating coil in it. The coil generates heat as power is supplied to it and the heat is transferred to water by convection. As the water come out from the tank, its temperature is raised. A certain amount of time is required for this process. I need to perform a cfd analysis for the same. The problem is that the temperature of outlet water is rising and falling abruptly. Kindly offer a solution fo this issue.
Old   February 20, 2017, 00:50
Vignesh Lakshmanan
Can you mention the case set up of your simulation? Because that is where you might have ended up with mistakes (May be!!!!)
Regards
Vignesh
Old   February 24, 2017, 06:19
Akriti
What exactly do you mean by case set up?
Old   February 26, 2017, 23:00
Vignesh Lakshmanan
The boundary and initial conditions and also a few snapshots of your geometry so that I can understand the problem
Regards
Vignesh
[OpenFOAM] Paraview plot time average tonyuprm ParaView 7 December 24, 2023 20:02
[OpenFOAM] velocity vs time plot in paraFoam raagh77 ParaView 6 January 29, 2017 03:09
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
directMapped problem panda60 OpenFOAM Bugs 4 July 8, 2010 11:23
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 15:09
