September 7, 2004, 19:35 |
external variable for pressure-gradient
hello,
I am using periodic flow. It would be nice if I can use "pressure-gradient" or "mass-flow-rate" information inside of my UDF code. I've checked the header file of sg_press.h there is interesting definition that i want to look at but how can I access that variable? If I try to call it out it shows error message. it's alread defined .... Thank you, all of you (especially Greg) I've learn lots from you. K.H. |
September 9, 2004, 01:15 |
Re: external variable for pressure-gradient
oh well,
I guess I just have to code a bit more to compute those variables from fluid field indy. |
CGNS Compiling | Diego | Main CFD Forum | 17 | December 21, 2014 01:40 |
emag beta feature: charge density | charlotte | CFX | 4 | March 22, 2011 09:14 |
error in COMSOL:'ERROR:6164 Duplicate Variable' | bhushas | COMSOL | 1 | May 30, 2008 04:35 |
Gradient of a User defined Variable | Ramadas | CFX | 2 | August 21, 2007 09:19 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 20:09 |
