September 6, 2004, 23:19 |
Spin coating
Hi... I am trying to solve the spin coating problem which a liquid is spreading on the circular plate.
It is almost same with the fluent vof tutorial model. The control volume is (5 * 140 mm) and , liquid volume is a quarter circle which is R = 4mm.(right lower corner). The model is axis(bottom), swirl, seg, vof and unsteady.(2D) As a case, I used the water with the swirl velocity, 10 rad/s. It seems to be "ok". However, if I use the water with the larger visocity or oil, error happens and iteration stops. I could see the comment "floating number invalid". So, please let me know what is the best way to solve my problem, specially to get the solution for the increased viscosity like silicon oil. Thank you so much to read. Please let me know the way to get out of this trouble. |
fluent doesnt read 1D coating mesh - advice needed | FuzzyDice | FLUENT | 5 | September 28, 2011 17:34 |
the volatilization after coating the paint | Jay | FLUENT | 1 | March 2, 2005 04:36 |
spin coating | JH | FLUENT | 0 | July 23, 2004 21:32 |
couple and spin index | novice | Siemens | 6 | July 8, 2004 04:31 |
Modelling of Filter paper and paint coating | Karthick | FLUENT | 0 | June 8, 2004 08:14 |
