unidirectional flow in porous media
Old   September 1, 2004, 17:04
Default unidirectional flow in porous media
Brian
I'm trying to simulate gas flow through a bundle of hollow tubes. Is it possible to model this bundle as a porous media while constraining the flow to only one direction (along the axis of the hollow tubes)? Does anyone have any experience with problems such as this?
thanks in advance for any help
Old   September 1, 2004, 17:40
Default Re: unidirectional flow in porous media
Evan Rosenbaum
Just set a very large resistance in the other coordinate directions.
Old   September 1, 2004, 17:53
Brian
evan, thanks for the post
i have been trying this, but i still get a great deal of flow in the two 'wrong' directions... i think i may have the resistance coefficients mixed up...
should the viscous resistance coefficient be small in the 'correct' flow direction and large in the 'wrong' flow directions?
thanks again
Old   September 2, 2004, 09:38
guru
Hello:
If you are planning to model porous media for "Tube Banks" you should be playing with Inertia Resistance. As C2 is very large & (1/alpha) can be taken as Zero for Flow through the Tube banks.
Referene : 6.19.2 of Fluent Help.
Correct me If you are wrong.
Regards, -guru.
Old   September 2, 2004, 10:02
guru
btw One more thing ...the the difference in the resistance coefficients shouldn't be more than 3 order. say If you have 200 1/m in the flow direction then other two directions shouldn't have more than 200e3 1/m for the better convergence..
regards-guru.
Old   September 2, 2004, 11:42
Brian
Guru, Thank you for the advice! I never thought to search the help files for "tube bank"... hopefully this will help.
Thanks again, Brian
Old   September 2, 2004, 11:53
Brian
Guru, Thanks for the tip! I ran a few iterations and then checked my contours/vectors and everything seems to be acting much more like it should. I really appreciate the help!
-Brian
How to model granular flow through porous media Axius FLUENT 2 August 7, 2014 11:34
Compressible flow through porous media? JoFFe CFX 2 November 1, 2010 05:50
Testing the integrity of POROUS media and por jump Azman FLUENT 0 July 31, 2006 12:11
Modeling porous media flow in prostar Nirmal Kumar Pathak Siemens 8 November 23, 2005 08:18
Flow resistance of porous media Desheng Kong Main CFD Forum 3 December 19, 2000 12:07
