Attention on simulation of microreactor
Old   August 27, 2004, 00:52
Default Attention on simulation of microreactor
TAMO2(from Japan)
If you simulate microreactor using VOF, you should be careful as follows;
if you set Courant number = 1, time step should be smaller than sqrt( dx^3 * density / surface_tension )
here dx:minimum mesh size
Old   September 13, 2004, 19:01
Default Re: Attention on simulation of microreactor
Janice
Hi, Tamo2:
What kind of problems are you working on in microreactors? I am working on 3D VOF in microreactors and got some problems. I need some helps, probably you are the best one.
Old   October 6, 2004, 01:01
TAMO2(from Japan)
I'm working on in MR as follows; (1) In Spiral MR, liquid-liquid and gas-liquid VOF model. (2) Laminar flow reaction.
And,I don't have good ideas about (2) avoiding numerical diffusion.
Old   October 6, 2004, 11:08
Janice
I think that we are working on the same area. Probably we can disscuss some issues together.
Which CFD code for aerosol simulation Andrea Panizza Main CFD Forum 6 February 17, 2023 14:44
Simulation of a complex wing in solidworks flow simulation niels1900 FloEFD, FloWorks & FloTHERM 6 April 20, 2011 11:44
GUI crash and simulation engine still running RPJones FLOW-3D 2 November 9, 2010 09:18
velocity profile export from a simulation onto another sudhirlv STAR-CCM+ 1 September 12, 2010 19:57
strange simulation error Ralf Schmidt FLUENT 2 May 4, 2007 14:02
