Pouring water in a tank
Old   August 26, 2004, 02:18
Default Pouring water in a tank
Karthick
I am trying to model the pouring of water in a tank, basically it is gravity involving flow. I am having a simple Cylinder, which is divided into 2 halves. The inlet is declared as pr outlet and top of the cylinder is patched with water and bottom domain is air. The common face is declared as interior. But the flow is not coming. I an using eulerian model.
Regards Karthick
Old   September 7, 2004, 13:44
Default Re: Pouring water in a tank
Arash
You should use the Vof model.
Old   September 7, 2004, 14:17
Titiksh Patel
Hi
can u explain me your problem more clearly.. I am not able to understand it fully..It sounds like it is a free surface flow, so VOF is suggested. Go thro' FLUENT manuals as well (Multiphase Models)
Regards, Titiksh
Filling Tank with Water leff CFX 7 August 21, 2017 08:47
Simple Water Tank Transient 88phil88 CFX 5 March 17, 2014 04:48
water jet into water tank Fred CFX 9 January 24, 2007 17:35
modeling spilling of water from a tank jemteo CFX 6 June 25, 2006 20:33
uptodate water distribution network fredius,magige,tanzanian,(e.a) Main CFD Forum 0 January 27, 2002 08:10
