Case in Fluent Tutorial 1
Old   August 24, 2004, 12:25
Default Case in Fluent Tutorial 1
Lam
Fluent tutorial 1 illustrates the solution for the water mixing of two pipes, with two temperatures. The elbow drain the warm water along it and the hot water flow into the elbow at the turning of elbow. Based on the information at page 1-2, problem description.
How to decide what kinds of boundary conditions should be used? Do anybody can give me idea why choose "pressure-outlet" as boundary condition of outlet? Why not "outflow"?
At the inlet, the turbulence intensity is given 5%, why "Intensity and hydraulic diameter" specification been used and why hydraulic diameter at velocity-inlet-5 been set as 32in?
Please help I need Fluent 6 tutorial mesh and case files... bbcorrozojr FLUENT 2 May 7, 2009 05:38
case and dat file of FLUENT tutorial Sajad Ranjbaran FLUENT 0 November 8, 2006 07:55
SOS tutorial fluent 5.3 kostas156 FLUENT 1 November 19, 2002 03:14
Fluent case file into Gambit Eric R. FLUENT 7 July 17, 2002 15:11
where to find old version Fluent tutorial guid Roger FLUENT 0 March 11, 2002 18:04
