incorporating learned knowledge in fluent
Old   August 23, 2004, 06:53
Default incorporating learned knowledge in fluent
Rakesh
I have just started out on learning FLUENT.I wanted to know whether it is possible to incorporate co-relations (say gas hold up corelations),developed empirically or using machine learning tools)in fluent as user defined function or incorporate knowledge into it as to when you expect a certain flow regime change.I will be very grateful if someone who has tried something like this or is aware of this, posts a reply.Is it possible to incorporate a known knowledge into fluent? thank you regards, mandar
A Problem of Fluent Interpreted UDF: parse error knight Fluent UDF and Scheme Programming 25 August 16, 2018 11:26
Fluent 6.3 32bit vs Fluent 12.0 64bit ibex7 FLUENT 7 April 18, 2011 03:44
Compared MRFSimpleFoam and Fluent in a centrifugal pump! renyun0511 OpenFOAM Running, Solving & CFD 8 July 6, 2010 07:24
Fluent 12.0 is worst then Fluent 6.2 herntan FLUENT 5 December 14, 2009 03:57
possibility of incorporating knowledge in CFX rakesh CFX 0 August 23, 2004 06:59
