air and sand flow through porous medium
Old   August 23, 2004, 05:49
Default air and sand flow through porous medium
Thiyagarajan
hi all, iam analysing flow through filter.in my filter problem, initially for air alone i used porousjump bc for filter and i got pressure drop across the filter(porous jump face). now, i want to introduce sand, so i used discretephase model, i injected sand from inlet and applied trap bc at porous jump bc, but i couldn't trap the sand particles at the filter(porous jump face).In the Fluent window, iam geting message like this, number tracked = 20760, escaped = 20760, aborted = 0, trapped = 0, evaporated= 0, incomplete = 0 how to get the particles trapped?in the Fluent users guide it is told that interior discrete bc can be used for porous jump, but interior is not there in the discrete bc. thanks for any suggestions.. regards.. Thiyaga.
Old   August 24, 2004, 01:58
Default Re: air and sand flow through porous medium
Chendhil
Hi Thiyaga,
Fluent by default will set the 'escape' BC to discrete phase particles at the outlet. If you want them to be traped in the interior domain, however, you may try setting the 'trapped' BC at the porous jump.
Chendhil.
Old   August 24, 2004, 02:46
Thiyagarajan
Thank you, Chendhil,
, i tried with trap bc, but i couldn't get any particles trapped. iam injecting particles from inlet and at the inlet, by default,Fluent assumes escape discrete bc,is it wrong?, then what discrete bc should b given at inlet. thanks for any suggestions regards Thiyaga
Old   August 26, 2004, 13:27
Chendhil
Hi
Escape BC for inlet is fine. Did you make sure that you have 'Trap' BC at the outlet and 'Reflect' BC at wall-type boundaries?
Chendhil.
