Airpak: natural convection in a duct
Old   August 19, 2004, 17:09
Default Airpak: natural convection in a duct
NeOmega
Hi all,
I made 3 models of a 200m long duct with two 1m^2 wide openings. They were angled at 30 degrees, 45 degrees, 60 degrees and 90 degrees.
The first 3 respective ducts worked fine. They had one side with a 500W heat flux, and the other sides ambient... and the air flowed out of the top side at speeds increasing with angle as expected.
However, the 90 degree (vertical) duct gave me some problems. The solver would not converge, and showed a circulation pattern inside the duct, with the downdraft side actually running along the heated side... clearly not realistic. Any suggestions on how to model convection off of a vertical heated side along the length of a duct?
Old   August 27, 2004, 06:53
Default Re: Airpak: natural convection in a duct
leungyk
have u switched off the radiation solver option ?
Old   August 27, 2004, 14:28
NeOmega
Actually I didn't. I'll give it a try, since 1 meter is definitely a small enough length to cause some heating on all sides.... however, it didn't happen in the other 3 angles.
natural convection problem with radiation jorien CFX 0 October 14, 2011 10:26
Natural Convection with heat generation krishnachandranr Main CFD Forum 0 July 28, 2009 05:22
Natural convection - Inlet boundary condition max91 CFX 1 July 29, 2008 21:28
Coupled vs Seg - Natural vs. Forced Convection Alex Siemens 5 December 12, 2007 05:58
natural convection in a vertical heated duct. SHANTANU CHAKRABORTY Phoenics 1 June 18, 2001 10:12
