Boundary layer on a wing
Old   August 18, 2004, 21:24
Default Boundary layer on a wing
Mark
So I have calculated the thickness of the turbulent BL over a 0.5m chord wing (NACA0009) of around 1.13cm. So I have set uniform a = 0.000715 b/a = 1.1 10 rows D = 0.0113 and used the wedge corner shape for the t.e.
Now the wing is 5m long and has no taper, or sweep or any crazy things, just a simple hershey bar wing
The error that I have recieved that the "3D boundary layer are limited to flat face groups with end contions around the boundary. The problems occur in the 'volume.2' along edge 'edge.378'" Now I checked and that edge is the trailing edge, so what is the more proper way of creating the BL s.t. I would not have problem with it volume meshing. Also on the tip of the wing do I also add the boundary conditions that are the same as the rest of the wing?
thank you
A question on "Specifying Boundary Layer Deformation Smoothing" didiean FLUENT 2 January 16, 2012 22:39
How to know the know the Boundary Layer thickness and the edge velocity on a 3D wing? mohammad Main CFD Forum 8 May 16, 2011 13:21
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
3D Boundary Layer Mario FLUENT 0 February 17, 2009 04:40
CREATION OF BOUNDARY LAYER Jibran Haider FLUENT 3 August 1, 2008 01:33
