Multiple UDFs
Old   August 17, 2004, 19:48
Default Multiple UDFs
Graeme
Hi I'm trying to control the velocities of 2 different velocity inlets with UDFs. I can't seem to use 2 seperate UDF's at the same time. Can I control two separate inlets with the same UDF? Or is there some way to use 2 or more UDFs?
Old   August 17, 2004, 23:35
Default Re: Multiple UDFs
Javier
You have to write the two udf on the same code file. Then you will see them separated on the udf panel.
Old   August 18, 2004, 18:47
Graeme
How exactly do you name more than one boundary condition? The examples in the tutorials/manual all only have one boundary condition that is being controlled.
DEFINE_PROFILE(unsteady_velocity, thread, position) Do i do DEFINE_PROFILE2? or something like that?
Old   August 18, 2004, 19:26
Rob Hart
no.
you need to do
DEFINE_PROFILE(unsteady_velocity2, thread, position)
or something like that. All that matters is that the two profiles have different names.
Rob
Old   August 28, 2004, 16:47
Bikash
hi Graeme,
im have the same problem as yours with the UDF. Im trying to use for temperature at the inlet and the ambient temperature both varying with time. the last one compiled overlaps the previous one. i guess you found the solution to your problem. please do help me with my problem. i would respect your time and thank you for your help.
thanks
bikash
how can i use multiple udfs hami9293 Fluent UDF and Scheme Programming 15 May 27, 2020 20:25
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 13:21
multiple UDFs mmdmov Fluent UDF and Scheme Programming 4 April 21, 2009 08:42
Multiple udfs? David Harris FLUENT 1 April 23, 2006 03:34
