UDF TO WRITE OUT DATA!!
Old   August 12, 2004, 12:33
Default UDF TO WRITE OUT DATA!!
Aishwarya
Hi i tried writing a UDF to write out the wall shear stress vector data(all the three components)at every node in the domain at every time step(it is an unsteady 3-d flow).The problem is that 1.it crashes after the first time step.There is nothing wrong with the code,is there anyone who has done something like this. 2.The format is very confusing. 3.There are 3000000 nodes.
Any help or suggestion will be greatly appreciated!
Aishwarya
Old   August 14, 2004, 11:32
Default Re: UDF TO WRITE OUT DATA!!
ccc
hi, aishwarya
can you post the relating code section?
good luck
accessing solver data with UDF macros Dushan FLUENT 1 April 22, 2017 22:05
UDF and experimental data in Fluent Rogerio Fernandes Brito FLUENT 0 November 25, 2008 10:32
Data logging in UDF carno FLUENT 2 October 6, 2008 02:43
UDF to read and write data Mcgregor FLUENT 4 June 9, 2003 14:21
UDF to write interp files Karl FLUENT 6 February 7, 2002 13:10
