Problem setting C_MU_T with DEFINE_ADJUST
Old   August 9, 2004, 10:34
Default Problem setting C_MU_T with DEFINE_ADJUST
Andy
i´m trying to change turbulent viscosity (for an extension of the ke-model; DEFINE_TURBULENT_VISCOSITY is not accessible in Eulerian multiphase) in the Eulerian model using UDF. I'm using a DEFINE_ADJUST , but I get an error message when I compile my code.
The compiler tells me: error C2106: '=' :left operand must be l-value
DEFINE_ADJUST(turb_adjust, d) { Thread *t; cell_t c;
thread_loop_c (t,d)
if (FLUID_THREAD_P(t))
begin_c_loop_all (c,t)
C_MU_T(c,t) = 1; /*C_MU_L works!*/
end_c_loop_all (c,t)
Same error occurs for C_MU_EFF. But if i use the C_MU_L no problem (or C_R(c,t))! So where´s the problem with the eddy viscosity?
I hope someone can help me out off this! Thanks.
Andy
Old   July 30, 2014, 05:09
Default Ask some questions
yuanmengyuan1989 is on a distinguished road
hello. i met the question similar with yours. i used the DEFINE_ADJUST to adjust the viscosity of the material. However, when the "C_MU_L" occurs in my UDF, it will make mistake as followings:
Error [cortex] [time 7/30/14 15:49:6]
FLUENT received fatal signal (ACCESS_VIOLATION)
1. Note exact events leading to error.
2. Save case/data under new name.
3. Exit program and restart to continue.
4. Report error to your distributor.
No matter how simple the UDF is, if the "C_MU_L= " occur, the error will appear.
do you know the reason why it happens?
yuanmengyuan1989 is offline   Reply With Quote
Old   July 30, 2014, 06:05
le hoang anh
lehoanganh07 is on a distinguished road
Originally Posted by Andy
;114244
thread_loop_c (t,d)
Andy
Hi
I think the value of C_MU_T(c,t) should be return real value.
lehoanganh07 is offline   Reply With Quote
Old   June 22, 2018, 03:53
AllenZHANG
AllenZHANG is on a distinguished road
Did you solve this problem? Thanks
AllenZHANG is offline   Reply With Quote
Problem in setting porosity region for rhoPorousSimpleFoam run_cfd OpenFOAM Pre-Processing 1 May 31, 2011 10:02
les setting problem, urgent Frank FLUENT 0 February 6, 2006 22:13
Problem setting AV Marko CFX 0 March 18, 2005 09:06
Problem setting C_MU_T with DEFINE_ADJUST sarah_ron FLUENT 1 February 24, 2005 13:11
Help setting up combustor problem Tom FLUENT 0 February 5, 2005 02:20
