help: how to define a variable density for solid! |
August 9, 2004, 02:47 |
Hi,everyone Thanks in advance for your help! I want to define a variable density which varies with temperature for solid material. Firstly, I write a udf for it, but soon i found that for solid material' density it donesnot support udf! How should I do?
August 9, 2004, 11:06 |
Re: help: how to define a variable density for sol
if you change density of solid the volume should be changed accordingly to conserve mass (thermal expansion). In order to calculate thermal expansion strains and stresses software (code) have to solve elasticity problem with corresponding boundary conditions. I assumed you tried this with fluent. Fluent does not solve elasticity problems, for that you can use ANSYS or ABAQUS.
August 9, 2004, 21:17 |
Thanks Alex Chirokov, but it will make the problem difficult! I just want to define a solid density that varies with temperature, could i define a liquid density where i define its viscosity infinite that it will not move£¿
August 10, 2004, 22:37 |
hi neng_ren, your question is interesting but I am still a little confused about it. Does the density variation in the solid region affect heat trafsering or other things in the flow? if not, I think you can leave this to postprocessing. good luck.
Two phase Eulerian model with variable solid density | ziglat2004 | FLUENT | 0 | September 16, 2011 18:06 |
density in function variable scalar | luisalva | CFX | 0 | May 12, 2010 19:28 |
LES solver with variable density for incompressible liquids | matthias | OpenFOAM Running, Solving & CFD | 1 | April 26, 2010 05:46 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
variable density | Shigunov | Main CFD Forum | 7 | September 26, 1999 13:08 |
