August 4, 2004, 13:28 |
Covert gambit file to polyflow file
Can anyone tell me how to convert the Gambit file to polyflow file? GAmbit end with" .dbs",while polyflow file end with ".msh" & ".dat"
Hope some one can help me out here. Thank A lot |
August 5, 2004, 04:12 |
Re: Covert gambit file to polyflow file
Hello John,
Instead of saving your gambit geometry try to export it in a .msh format. Before that, you maybe have to specify your solver. Good luck. |
August 5, 2004, 06:22 |
I already specify the solver for POLYFLOW in gambit before i do modelling & meshing.
I do the samething as the gambit tutorial do. But it export Neutral format file("xxx.neu") Hope someone can give advise again. |
August 5, 2004, 08:26 |
If you are using POLYMAN, in the tool menu, there is an option Convert a Gambit Neutral file (i.e. the xxx.neu file.
If you are not using POLYMAN, in the main menu of POLYDATA, there is an option Convert a mesh file under which you can find the option Convert a Gambit Neutral file. Both ways will create the xxx.msh file. |
August 5, 2004, 10:38 |
Thank a lot to you guy.
I get it now. but new problem come out after solve this problem. when i open the .msh file with polydata, it show message "Unable to create the skeleton of the mesh. At least 2 boundaries per sub-domain are needed!" i still able to see the 3-D model in polydata. CAn anyone give advise?? why can not create mesh? |
August 6, 2004, 09:31 |
You did not define the boundaries in Gambit. Refer to the Users GUide and Example manuals if you don't know how to do it.
[OpenFOAM.com] OpenFOAM 1.7.1 installation on LINUX UBUNTU 10.10 | electrosin | OpenFOAM Installation | 40 | May 31, 2016 06:11 |
1.7.x Environment Variables on Linux 10.04 | rasma | OpenFOAM Installation | 9 | July 30, 2010 05:43 |
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found | piprus | OpenFOAM Installation | 22 | February 25, 2010 14:43 |
[Gmsh] Compiling gmshFoam with OpenFOAM-1.5 | BlGene | OpenFOAM Meshing & Mesh Conversion | 10 | August 6, 2009 05:26 |
[OpenFOAM] Paraview command not found | hardy | ParaView | 7 | September 18, 2008 05:59 |
