How to run fluent in LINUX
Like Tree4Likes
Old   September 8, 2011, 15:13
Default fluent for linux 64 bit
  #21
amir okhovat
amirokhovat is on a distinguished road
Send a message via Skype™ to amirokhovat
please put fluent link for linux 64 bit thanks very much
amirokhovat is offline   Reply With Quote
Old   September 11, 2011, 12:39
Smile
  #22
vlg
villager is on a distinguished road
[QUOTE=Paola;322945First, my computer has an architecture: x86_64 (you can see it with "uname -m" command). So I had to set the variable FLUENT_ARCH equal to lnx86...[/QUOTE]
On my home computer:
uname -m
x86_64
and it is 64-bit system.
I use FLUENT_ARCH=lnamd64
because of FLUENT_ARCH is FLUENT architecture, not architecture of the system!
And u use FLUENT_ARCH=lnx86 because you have x86 fluent package.
Tuning Ubuntu (64-bit) to run Fluent 6.3.26
link:
http://www.cfd-online.com/Forums/flu...64-bit.html#20
villager is offline   Reply With Quote
Old   September 12, 2011, 05:16
Paola Alpresa Gutiérrez
Paola is on a distinguished road
Oh! That was why I was all mess up at the begining
Ok, so is it a Fluent with a lnx86 architecture appropiated for my system 64bit?
Thank you, villager!
Paola is offline   Reply With Quote
Old   September 13, 2011, 15:17
vlg
I think so)
I run Gambit 2.3 x86 with FLUENT_ARCH=lnx86 and Fluent 6.3 with FLUENT_ARCH=lnamd64 on my amd64. I think,if somebody use Intel x64 processors, he must specify FLUENT_ARCH=lnia64.
You can run x86 programms in 64-bit system, but you cant't run 64-bit programms in 32-bit system.
So, when you buying (or downloading) fluent, check its version to be compatible with your computer.
Old   April 6, 2012, 08:00
Lightbulb In addition...
  #25
vlg
No, lnia64 option is only for Itanium processors, and lnamd64 for both Intel and Amd processors.
Old   May 24, 2016, 17:47
Farzin
FarzinD is on a distinguished road
Originally Posted by stuart23 View Post
Paola,
You need to first know where you have installed Fluent. If you don't know, open a terminal window and type:
sudo updatedb
locate fluent
This will give you a bunch of files where fluent is installed. Find the one that looks something like: ....../ansys/13.0/v130/fluent/fluent13.0.0/bin/fluent. The last 2 directories "bin/fluent" will be identical. The rest of it may be different depending on your version.
This file bin/fluent is the launcher. The easiest way to launch is by first nothing the path to "bin/fluent", and then typing in the terminal: (substituting your own path for mine)
cd /apps/ansys/13.0/v130/fluent/fluent13.0.0/bin
./fluent
Stu
Thanks. This was really helpful.
FarzinD is offline   Reply With Quote
Old   December 4, 2019, 18:25
Ashi
ashi.chauhan@mq.edu.au is on a distinguished road
Hi There I am using Fluent in Linux and am using .jou file with following commands;
file read-case file name.cas
file read-data file name.dat
file auto-save data-frequency 0
solve update-physical-time
file auto-save data-frequency 100
solve dual-time-iterate 500 50
file write-case end-file name-1.cas
file write-data end-file name-1.dat
exit
yes
There is an error in the above mention code because I could save data files at every 100 intervals.
Can anyone help me with this?
ashi.chauhan@mq.edu.au is offline   Reply With Quote
parallel fluent setting in linux m2montazari FLUENT 3 October 10, 2011 17:42
FLUENT in Windows Serial and Linux Parallel sham83 FLUENT 0 June 1, 2011 00:38
Dual Boot Windows and Linux and Go Open Source andyj Main CFD Forum 2 October 21, 2010 17:49
Fluent for linux Patryk FLUENT 0 July 20, 2009 20:04
Fluent Remote Simulation Facility Service (RSF) di Rami FLUENT 2 June 4, 2008 06:38
