July 28, 2004, 12:32 |
Temperature mixing
Hi guys, don't know if anyone can help me with this, but its driving me mad!
I am having problems with Polyflow. I use gambit for mesh generation, Polydata, Polyflow and Flpost. I am trying to run what i think is a simple problem and Polyflow keeps crashing and coming up with the error " polyflow.exe has generated errors and will be closed by Windows. You will need to restart the program. An error log has been created" This is in a seperate popup box than the Ms-Dos window I am running polyflow in. This is just a simple time dependant problem using two temparature imposed inflows. these inflows just go into a mixing chamber where one side is the outflow. The parameters I am using are just the same as the transient newtonian flow in the polyflow examples menu. Any help would be great Cheers Kev |
mixing cup temperature | gtheo | CFX | 4 | October 26, 2016 18:02 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 07:27 |
cup mixing temperature | debuchak | FLUENT | 0 | June 22, 2009 15:21 |
mixing cup temperature using posdat.f | Thiyagarajan | Siemens | 1 | November 28, 2007 01:00 |
mixing cup temperature using posdat.f | Boban | Siemens | 0 | July 8, 2005 11:46 |
