July 28, 2004, 11:04 |
negative cell volume in dynamic mesh
To Flunet users, i am using a dynamic(deformed) mesh to study flapper valve movement in combustion chamber caused by the difference between the combustion gas and atomisphere pressure. when the program runing, it alaways show the message " error: update-Dynamic-mesh failed. negative cell volume detected error object: #f"
when i do the grid check, it shows in the console: checking face handedness zone 27: 8121 right-handed, 2-left-handed zone 7: 133 right-handed, 2-left-handed i think the negative cell volume may be caused by the left-handed face handedness appeared in runing. the question is how to prevent this? should i change some controll parameters or remesh the grid? thanks for any suggestions. WU Zhonghua |
Regarding Negative volume detected in Dynamic mesh | Vinay Morabad | FLUENT | 10 | December 16, 2015 01:31 |
Dynamic Mesh - negative cell volume | orie | FLUENT | 1 | January 22, 2011 07:05 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 20:43 |
Negative volume in dynamic mesh | Max | FLUENT | 1 | August 7, 2006 06:18 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 05:15 |
