July 24, 2004, 00:48 |
Mesh size
hi, i would like to know what is the default unit for the mesh size in Fluent/ Gambit. and also how do i find out the density and the size of the mesh of my geometry from Gambit/ Fluent? help very much appreciated. thank you in advance.
July 26, 2004, 08:23 |
Re: Mesh size
I'm not but in gambit mesh is generated in [m]. You should always check your mesh in fluent by option grid>scale.If you have to large your mesh i.e sting the scale factor 0.001 Also you can check your mesh in fluent by grid>info.
July 26, 2004, 18:37 |
Re: Mesh size
You can make you mesh in any unit in Gambit (not just m). You then scale it (to m) in Fluent using the scale (convert function) and by specifying what ever unit you used for creating your mesh in unit. All meshes are converted to m when using fluent.
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 09:54 |
Mesh motion with Translation & Rotation | Doginal | CFX | 2 | January 12, 2014 07:21 |
Gambit Unstructed (Tet) Mesh - size control | newbie | FLUENT | 3 | August 26, 2008 12:38 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 19:10 |
How to decide the mesh size? | echo | Siemens | 1 | May 23, 2006 06:34 |
