Trouble in energy residuals
Old   July 23, 2004, 02:08
Default Trouble in energy residuals
Prasad Dudhgaonkar
I use surface injection model in DPM for injecting evaporable liquid in air in unsteadystate. Untill when the liquid had not come into contact with air, the convergence for each time step (50 micro seconds) was quick (some ten to twenty iterations). Since when the liquid has started entering the high velocity air stream, as seen in the particle tracks, the energy residual has remained stagnated at 1.12e-6 (convergence criteria set is 1e-6) even after 500 iterations.
I will be grateful if somebody enlightens me on this.
Thanks, Prasad
Old   July 23, 2004, 05:11
Default Re: Trouble in energy residuals
George
Residuals are not the only convergence criterion we have and in more complex cases like yours it often happens that we don't reach the standard convergence limit. If your energy residual stagnates without large oscillations than you may assume convergence even though the value of the residual is somewhat elevated above the prescribed limit. Please see UG for an explanation, maybe you will then be able to identify the actual reason of this behaviour.
Good luck,
George
energy in sonicFoam joern OpenFOAM Running, Solving & CFD 1 September 24, 2019 01:15
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 16:45
divergence in energy residuals swarley FLUENT 2 May 22, 2008 09:09
SIMPLE and energy equation convergence Fabio Main CFD Forum 0 June 1, 2007 07:06
Convergence - scaled vs unscaled residuals HS FLUENT 1 November 7, 2005 06:45
