3D wing
Old   July 19, 2004, 03:34
Default 3D wing
zubair
hi dears i am trying to model 3D wing in gambit using the link http://www.enseeiht.fr/hmf/travaux/C...nual/index.htm when i import the file to gambit as directed in this link i get some points along Xaxis and some along y axis so instead of getting symetric airfoil i got different airfoil.please guide me what is my fault. thanks a lot zubair
Old   July 21, 2004, 09:00
Default Re: 3D wing
James
Hi, It is important that your vertex data file has three columns corresponding to X coordinate, Y coordinate and Z cordinate, these columns must be seperated by a space (If I remember correctly). Also, I don't see the need for the first line corresponding to the number of curves and points. If you leave this line out it should help. Hope this helps.
3D Wing Analysis Ed FLUENT 5 April 13, 2019 14:07
[ICEM] O-grid around wing geometry Anorky ANSYS Meshing & Geometry 15 November 27, 2017 14:43
Forward swept wing simulation abid Siemens 1 June 16, 2012 14:26
[Gridgen] Blocking topology for blunt wing siw Main CFD Forum 3 July 21, 2010 14:55
Isolating wing induced drag component siw CFX 2 June 22, 2010 11:21
