UDF in parallel version of fluent
Old   July 13, 2004, 07:34
Default UDF in parallel version of fluent
yobee
Hi I have linux pc cluster. And, only parallel version of fluent was installed on that machine. The machine has not serial version, but only parallel version.
To test capability of udf, I copy one code from UDF Manual, then, compiled it. But, When Fluent loaded the UDF library, Fluent said that: "Primitive Error at Node 0: open_udf_library: No such file or directory"
What's the problem?
Old   July 20, 2004, 08:19
Default Re: UDF in parallel version of fluent
Micha
Check udf handbook chap.7.3.1: " 7.3.1 Common Errors Made While Loading Your Compiled Library
You will get an error message when you try to read a case file that was originally saved with a shared library that you have subsequently moved to a different location.
Opening library "libudf... Error: open_udf_library: couldn't open library: libudf/ln86/2d/libudf.so
You will get an error message when you try to load a shared library before it has been built.
Opening library "libudf... Error: open_udf_library: No such file or directory
Special Considerations for Parallel FLUENT
If you are running the parallel version of FLUENT on a Windows network, the directory containing the shared library (e.g., sharedlibudf) must be shared with all of the remote nodes in the cluster. If you forget to enable the sharing option for the library directory using the Windows Explorer (see Step 8 of the previous section), then FLUENT will hang when you try to load the library (e.g., sharedlibudf) in the Compiled UDFs panel. "
Old   August 5, 2004, 01:36
Mahesh
As far as I know, for a parallel license one serial license is required. Please check it out with ur support.
Mahesh
Fluent UDF on parallel computing Andrea Fluent UDF and Scheme Programming 22 August 12, 2015 08:44
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 23:14
Saving *.cas and *.dat from Fluent parallel version Pfalcon FLUENT 2 August 14, 2009 15:57
compiling my UDF Seyed Farid Hosseinizadeh FLUENT 22 February 14, 2006 11:19
UDF in parallel fluent (windows based) Leon FLUENT 0 March 10, 2005 10:15
