July 12, 2004, 23:30 |
DPM + Eulerian Model
Hi all,
I have a eulerian 2phase model with air and water. I want to inject a third phase using the DPM. However the DPM phase is only interacting with the primary phase in the Eulerian model. Is there a way of making the DPM phase interact with both the primary and secondary Eulerian Phases, or do I have to write a UDF Thanks in advance Shane |
July 13, 2004, 06:36 |
Re: DPM + Eulerian Model
The secondary eulerian phase represents particles, so do you think it is possible to compute the interactions between 2 class of particles ????
July 14, 2004, 09:26 |
Dear Shane,
I am also having same type of problem. But please tell me whether can we combine DPM and Eulerian model in Fluent? Because both are different multiphase concepts. Can you able to see the particle injections in your model? Please be sure about it. Regards Karthick |
Water subcooled boiling | Attesz | CFX | 7 | January 5, 2013 04:32 |
Two phase Eulerian model with variable solid density | ziglat2004 | FLUENT | 0 | September 16, 2011 19:06 |
Mixture and Eulerian Model | Hassid S. | FLUENT | 1 | August 9, 2007 08:24 |
DPM vs Species transport model | osh | FLUENT | 0 | August 19, 2005 23:15 |
Two phase Eulerian Model Problem | senthil | FLUENT | 5 | May 21, 2003 03:55 |
