July 8, 2004, 11:04 |
Where case files are written
I am reading a FLUENT case file that was created and originaly written on a different computer. When I read and run this case file on my current computer I get an "Error writing" because it is using the same path where it was originally written. How can I change the directory where the case is written so I don't get this error.
July 8, 2004, 16:13 |
Re: Where case files are written
You would have to write the case and Data again once you read your stuff.
July 8, 2004, 17:17 |
Ajay, I have tried that many times. It will read from the current directory, but tries to write to the old path. See below.
Reading "c:\fluent\eugene\5pipes\5pipesallref with water3.27-.18-277test.dat"... Done. iter energy p-18 p-20 p-21.83 p-23.66 p-25.5 p-27.33 p-29.16 p-31 p-33 p-35 p-37 p-39 p-41 p-43 p-45 time/iter Writing "G:\eugene\5pipes0001.cas"... Error: sopenoutputfile: unable to open file for output Error Object: "G:\eugene\5pipes0001.cas" Error: Error writing "G:\eugene\5pipes0001.cas". Error Object: #f |
July 9, 2004, 03:24 |
I think you are using the "autosave" option. Try to change the path for the autosave file to your new directory and it should york.
[snappyHexMesh] Editing the motorBike case, loading diffirent .stl | btgyd | OpenFOAM Meshing & Mesh Conversion | 1 | September 26, 2011 18:24 |
Video from case and data files | girino | FLUENT | 9 | March 29, 2010 03:41 |
Different case files activate ALE Eq. | kevin | FLUENT | 0 | November 2, 2006 14:39 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 13:24 |
Pb with writing the Case and Dat files | Sam | FLUENT | 2 | May 14, 2004 12:16 |
