July 6, 2004, 07:11 |
Error in Fluent
Is there someone who knows what is this error, and how can I avoid it ? Error: couldn't allocate fine level coefficient matrix Error object: () thk's |
July 7, 2004, 06:01 |
Re: Error in Fluent
this usually comes when u tries to use coupled solver, its been noticed but i don't know the fix for it, change courant number some times it works
July 9, 2004, 10:48 |
Re: Error in Fluent
Fluent is saying it can't get enough memory from the system so that it can allocate the coefficient matrix.
July 28, 2004, 06:59 |
Re: Error in Fluent
U need to go for higher processing speed. Ur current configuration is not supporting the mesh size.
Mahesh |
Stopping a Fluent batch job AND saving the data! Possible? | Volker Pawlik | FLUENT | 13 | December 28, 2020 05:16 |
A Problem of Fluent Interpreted UDF: parse error | knight | Fluent UDF and Scheme Programming | 25 | August 16, 2018 11:26 |
Two questions on Fluent UDF | Steven | Fluent UDF and Scheme Programming | 7 | March 23, 2018 04:22 |
Compared MRFSimpleFoam and Fluent in a centrifugal pump! | renyun0511 | OpenFOAM Running, Solving & CFD | 8 | July 6, 2010 07:24 |
Problems in lauching FLUENT | Lourival | FLUENT | 3 | January 16, 2008 17:48 |
