udf trouble
Old   July 6, 2004, 07:04
Default udf trouble
Eric
Hello!
I have downloaded a UDF example "particle DPM slip velocity" on FLuent's website. I've compiled it and the Fluent's compiler gives this error back: "line 14: structure reference not implemented" This line is: p->user[0]=mag_sl;
Has anyone a solution ?
Thanks a lot, Best regards Eric
Old   July 6, 2004, 15:49
Default Re: udf trouble
Ajay
I have encountered this error when I interpreted the UDF instead of using compiled UDF.
Compiled UDF needs building and loading the libraries
-Ajay
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 23:14
Trouble: Sandia UV UDF on FLUENT 12.0.16 RPJones Fluent UDF and Scheme Programming 31 May 25, 2011 12:15
Parallel INIT UDF trouble mil3st3g Fluent UDF and Scheme Programming 2 January 6, 2011 15:07
[Help Please], Trouble Using UDF to Import Velocity Data -- But All Zeros :( rockymountai FLUENT 1 November 11, 2009 17:30
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 05:03
