Calculating Heat flux
Old   July 6, 2004, 06:47
Default Calculating Heat flux
Andrew Garrard
Hello everyone, I am currently haveing some trouble getting my head around somthing, and would appreciate some assiatance. I am trying to create via a UDF the same conditions that are used in the "coupled" wall boundary condition for heat flux from solid to fluid. I tried passing temperature from on side to the other, but that didn't work (I suspected it would be too easy). Dose anyone have any help with this one? I found this in the Fluent manual, but it didn't make much sense to me:
qid = cid[0] + cid[1]*C_T(c0,t0) - cid[2]*F_T(f,t) - cid[3]*pow(F_T(f,t),4)
Sign of Heat Flux at wall Kyung FLUENT 2 February 26, 2016 17:25
Calculating heat flux hugo17 OpenFOAM Post-Processing 4 May 27, 2015 13:47
Heat Flux at wall in a conjugate heat transfer problem Chander CFX 2 July 9, 2011 23:22
Heat Flux Wall Boundary Confusion. Joee FLUENT 1 August 21, 2010 13:20
Heat flux in ansys cfx juliom OpenFOAM Running, Solving & CFD 2 April 14, 2009 15:30
