Fluid Structure Interaction
Old   July 5, 2004, 07:32
Default Fluid Structure Interaction
Apollo
Hi. Can I seek some advice about a CFD problem??? I might be doing a project, which involves 6 Degree of Freedom Navier Stoke Equations. This means that the CFD problem has the fluid flow and solid body motion solved simultaneously. The fluid flow influence the motion of the solid body, while the solid body motion influence the fluid flow. Can this be solved using FLUENT software? Currently, I know that in FLUENT solver, the motion of the solid body is fixed arbitrarily and then we find the fluid flow field. But in actual situation, the fluid flow field will influence the solid body motion and in turn influences the fluid flow. Besides using Fortran programming, what other software can I use to do that problem??? Is there a new version of FLUENT software coming up whereby I can do this fluid structure interaction (the fluid affect solid body motion, solid body motion affect fluid. But are solved simultaneously).
Old   July 6, 2004, 05:07
Default Re: Fluid Structure Interaction
Shaji
I think you can use FIDAP which is specifically meant for Fluid- Structure Interaction.
Old   July 6, 2004, 06:32
Karthick
Hello Apollo
As per my knowledge, in Fluent we can perform only one way of fluid structure interactions. I think in the newer version of CFX i.e., CFX 5.7, both ways of fluid to solid and solid to fluid interactions can be performed.
Regards Karthick
Old   July 6, 2004, 06:56
Nilesh
Fidap allows both way of interaction. However, the deformation should not be very large. The geometry / mesh topology should not change.
-Nilesh
Old   July 6, 2004, 09:39
karthick
hai Nilesh,
"Both ways of interation"--by this you mean that physical disturbance of solid can be applied on to the fluid using FIDAP? Can you tell still more clearly? thanks and regards karthik
Old   July 6, 2004, 09:44
Nilesh
Fluid will cause the deformation in the solid, which in turn will change the boundary of the domain and mesh. The fluid equation will be solved in this new domain. The iterations will be repeated till the steady state is reached.
Old   July 6, 2004, 10:23
Frank Meißen
In the release-info of the upcoming Fluent 6.2 (3rd or 4th quartal) it is written:
Release Notes for FLUENT 6.2.3 - Beta Version:
New features in FLUENT 6.2 are listed below.
*Models
**Dynamic mesh modeling
***6-DOF solver
Frank
Old   July 6, 2004, 17:00
Bob
If you are a member of www.fluentusers.com they have a 6 DOF UDF that you can save.
Old   July 7, 2004, 18:54
Zhihua
ANSYS can solve fluid-structure interactive problems.
Fluid structure interaction on baloons vinz OpenFOAM Running, Solving & CFD 38 September 14, 2016 13:38
Fluid Structure Interaction using icoFsiFoam Problems lr103476 OpenFOAM Running, Solving & CFD 79 August 7, 2014 10:30
Optimization or fluid structure interaction Steve_NTUA Main CFD Forum 9 August 29, 2006 04:40
Fluid structure interaction tomm FLUENT 2 September 16, 2004 05:33
Fluid Structure Interaction Gabor Balint FLUENT 2 January 5, 2000 14:08
