6 Degree of Freedom Navier Stoke Equations
Old   July 5, 2004, 06:34
Default 6 Degree of Freedom Navier Stoke Equations
Apollo
Hi. Can I seek some advice about a CFD problem??? I might be doing a project, which involves 6 Degree of Freedom Navier Stoke Equations. This means that the CFD problem has the fluid flow and solid body motion solved simultaneously. The fluid flow influence the motion of the solid body, while the solid body motion influence the fluid flow. Can this be solved using FLUENT software? Currently, I know that in FLUENT solver, the motion of the solid body is fixed arbitrarily and then we find the fluid flow field. But in actual situation, the fluid flow field will influence the solid body motion and in turn influences the fluid flow. Besides using Fortran programming, what other software can I use to do that problem??? Is there a new version of FLUENT software coming up whereby I can do this fluid structure interaction (the fluid affect solid body motion, solid body motion affect fluid. But are solved simultaneously).
Navier Stokes equations in rotation frame..? vinayender Main CFD Forum 2 December 1, 2009 01:12
degree of freedom ztdep Main CFD Forum 1 January 12, 2009 09:16
Navier Stoke eq. for Sliding Mesh technique Jackie Main CFD Forum 1 July 3, 2006 12:47
Navier Stoke eq. for sliding mesh technique Jackie FLUENT 0 July 1, 2006 03:42
6 Degree of Freedom Navier Stoke Equations Apollo Main CFD Forum 6 July 21, 2004 17:46
