Air bearing
Old   July 2, 2004, 18:38
Default Air bearing
dinesh rakwal
I have a problem in which i am supposed to simulate the air flow between two surfaces. Now generally in case of air bearings the thickness of film is about 10microns or less. and i have tried using fluent which gives me answers for anything above 100 microns but below it the solutions do not converge. It is a pressure inlet pressure outlet problem.Is it possible to simulate bearing lubrication and the forces generated by it using fluent?.What are the least dimension with which we can play in fluent?. thanks dinesh
Bearing and air simulation R.Escartin CFX 1 December 12, 2011 08:03
air hammer in aerostatic bearing spcwin Main CFD Forum 0 September 8, 2010 09:16
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 08:59
Air bearing modelling Dave Larkham CFX 1 October 19, 2008 20:10
UDF for air gap in a foil bearing Rishikesh FLUENT 0 September 22, 2008 02:12
