variable heat transfer coeffitient
Old   July 1, 2004, 01:49
Default variable heat transfer coeffitient
Arky
How to access heat transfer coeffitient boundary condition? I need to change the value, depending on the surface tempereture.
Thank you.
Old   July 1, 2004, 15:20
Default Re: variable heat transfer coeffitient
Ajay
You could use a UDF ( user defined Function ) -Ajay
Old   July 3, 2004, 09:24
Arky
what is the variable type for the heat transfer coeffitient?
Old   July 5, 2004, 02:54
Ajay
Heat transfer coefficient is defined as q/delta_t
q = heat flux ( w/m2) and delta_t = temperature difference.
If you know these two you could find your heat transfer coefficient.
Old   July 6, 2004, 00:44
Arky
thank you, I'll try to
Old   July 22, 2004, 11:23
Ravi
Dear Arky
I am also facing the same problem. I want to specify heat transfer coefficient at various points in my domaain. But that option is not directly available in "Read profile" option. Can you please tell me how I can specify the heat transfer coefficient through udf/some other way?
Thanks in advance
Ravi
Two-sided Wall Heat Transfer BC - No Separate Solid Mesh and No Heat Transfer Coeff swahono OpenFOAM Running, Solving & CFD 10 October 15, 2018 06:43
Thin Wall Heat Transfer BC for rhoSimpleFoam swahono OpenFOAM Running, Solving & CFD 12 October 4, 2013 12:49
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Heat Transfer in Porous Medium eryan STAR-CD 0 September 28, 2010 14:14
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
