Points and face in gambit
Old   June 30, 2004, 05:32
Default Points and face in gambit
Lio
Is it possible to create a 3D face (in fact it must represent the ground around mountains) in gambit 2.0 only with points which don't have the same altitude ?
Thank's
Old   July 2, 2004, 03:42
Default Re: Points and face in gambit
mukkarum
yes
select three points and create face. after creating face on all points, merge them.
Hope this help!
Old   July 2, 2004, 03:52
Lio
Thank's mukkarum,
but my file contain about 1e+6 point ! And above all, they don't are organized in a regula grid, so I just wanted to know if it wasn't possible to "automatise" the creation of my face.
bye
Old   July 3, 2004, 05:09
mukkarum
I think u r using revers engineering, and getting points from laser scanner. Image viewer is best to fit a face on a number of points.
I think first create face in any other software and then import .igs format in gambit.
If you can, send the .dbs file to me.
I would try with somedifferent softwares.
You can also contact to fluent support to create face directly in gambit.
Thanks
Mukkarum
Old   July 5, 2004, 04:13
Lio
thank's, I have found the solution
Old   July 6, 2004, 00:49
mukkarum
What the solution have you found??
Old   July 6, 2004, 03:54
Lio
I have developped a code in C which reorganize my points in a regular grid. Then I have linked all the nodes 3 per 3 creating polygons...and now, it works
[blockMesh] Internal walls of zero thickness anger OpenFOAM Meshing & Mesh Conversion 23 February 6, 2020 19:25
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 06:50
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 08:36
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
