Meshing
Old   June 27, 2004, 13:28
Default Meshing
Kevin
Dear Expert,
I have a problem meshing my model. Mine has a complicated structure that meshing it is not successful. Basically, I have parts and air around them. Because there are many parts, my fluid region has many cavities, and the meshing fails. I tried many many different methods that are introduced in the tutorials, but i have no luck so far. I know I-deas can mesh my model. Problem meshing with I-deas is, when I import the meshes into GAMBIT, unnecessary surfaces/volumes are created at interfaces between air and parts (cavity area). My question is, is there any way avoid these? Or, does anyone have know-how to share in meshing? Thanks in advance.
Old   June 28, 2004, 05:04
Default Re: Meshing
lingo
Hi,Kevin:
When you import the model into Gambit,you need to merge small lines,surfaces before meshing.I think the unstructual grid is needed for your case.Hope this helps.
Regards
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing David-CFD ANSYS Meshing & Geometry 1 April 1, 2011 06:22
Best Meshing scheme for Cylinder Nutrex Main CFD Forum 4 July 29, 2008 12:03
Meshing locks workbench window. andy2o CFX 0 February 1, 2008 06:01
Singularity of grid?Volume meshing vs face meshing Ken Main CFD Forum 0 September 4, 2003 12:09
Volume Meshing & Face Meshing? singularity of grid ken FLUENT 0 September 4, 2003 12:08
