June 26, 2004, 03:23 |
solution is not converging
Hi friends I am working on temperature disturbution on fins in heat exchangers ,my boundary conditions for coolent flow -inlet(velocity-inlet),outlet(OUTFLOW) Air flow-inlet(velocity-inlet),outlet(Pressure-outlet)
my prob is my solution does not converge ,for first 70 iteration it reachesa residue of 3.4X 10E-3 from there onwards its keep on flutuating between 4.23X 10E2 2.55x10E-2 ,evn afetr 400 iteration ,wat cud be the prob Help me to solve this prob |
June 28, 2004, 04:34 |
Re: solution is not converging
Hi; Your convergence problem can be refered to many things. A general option to help solution convergence, is decreasing under relaxation factors. Of course, you should not set them below (0.1). For unsteady calculations, this problem can be refered to a high time step. You should decrease its value. If you model a compressible problem, it is strongly recommended to do not use velocity for inlet boundary. You should use pressure inlet or far field or mass flow rate B.C. If you use a turbulence model, take care about Y+ on your wall B.C. Take care about your choosen computational domain. For an external flow, you should locate your external boundaries far enough from bodies or generally high gradient regions. Oh, a main mistake can be about the location of outflow B.C. You must locate this B.C. far enough in a region with zero velocity gradient.
hope this help you ROOZBEH |
June 28, 2004, 09:01 |
I'd suggest not to mix, if possible outflow and pressure outlet boundary conditions. Usually a pressure outlet allows to obtain a more stable and better converging solution.
Hi ap |
Trying to perform test validity of Fluent with simulation of 2D airfoil | didiean | FLUENT | 39 | December 5, 2015 14:31 |
Solution not converging | Alex | FLUENT | 5 | April 14, 2015 01:55 |
interFoam solution tolerances | mgdenno | OpenFOAM | 4 | September 13, 2011 13:58 |
Unsteady solution | Christophe | FLUENT | 0 | August 11, 2006 12:13 |
Discussion about Mesh independant solution | Seb | Main CFD Forum | 13 | May 22, 2001 14:37 |
