June 18, 2004, 14:36 |
Fourier Transform (Spectral analysis)
Hello to all!
A short summary of my task: I am simulating a supersonic flow (M=1.5) through a rectangular channel over a cavity on the bottom of the channel with Fluent 6.1. The calculations are unsteady (time step 1x10e-6). In order to investigate the pressure oscillations on the top wall of the channel (opposite of the cavity) I define points at the top wall and write the pressures over time in a .OUT file. Problem: If I want to do a FFT analysis to plot the Pressure over the frequency I obtain untrue results. Is there a other way in fluent to present the pressure oscillations? Thank you, for any response! |
De-aliased Fourier spectral method | TTY | Main CFD Forum | 0 | November 10, 2010 17:55 |
Poisson equation fourier transform before discretization | yohey44 | Main CFD Forum | 0 | November 9, 2010 13:00 |
Fast Fourier Transform | Lourival | Main CFD Forum | 21 | June 7, 2007 01:53 |
Fast Fourier Transform | Lourival | FLUENT | 0 | May 16, 2007 15:02 |
neumann analysis using fourier series | student | Main CFD Forum | 1 | October 24, 2002 09:55 |
