Dynamic Meshes
Old   June 15, 2004, 09:57
Default Dynamic Meshes
F Bos
I am working on the unsteady flow around flapping (plunging and rotation) wings using moving meshes. This week I succeeded in using tetrahedral elements in combination with spring-based smooting and local remeshing using the default values given in the Dynamic Mesh tutorial (valve). But in the end I want to use hexahedral elements. I have the following 2 questions:
* After a couple of plunging periods I got a segmentation fault because negative cells occur. How is that possible? Why is the mesh at t=0 not the same at t=T (period)?
* I want to use hexahedral elements. Do I have to use the dynamic layer mesh update method? I tried it without succes. It is not used in the tutorial, so I do not know what a respectable values for the split and collapse factor coefficients?
I hope that someone has encountered typical problems concerning the use of dynamic meshes with Fluent.
Thanks in advance, Frank
Old   July 6, 2004, 06:59
Default Re: Dynamic Meshes
Karthick
Are you using In cylinder flow dynamic mesh model?
Regards Karthick
Dynamic Meshes Arturo FLUENT 2 May 13, 2008 07:23
question about dynamic meshes zhhwoo FLUENT 0 August 2, 2006 23:36
Error Message in Tutorial: Using Dynamic Meshes Alex FLUENT 3 February 20, 2006 02:44
Dynamic Meshes with Mixture Model cfdtoy FLUENT 3 April 13, 2004 22:16
Dynamic Meshes Cfdtoy FLUENT 2 February 6, 2004 13:14
