Define mass fraction for -ve velocity inlet/outlet |
June 14, 2004, 04:37 |
To all fluent expert all over the world:
I got a simple question here. How to define mass fraction for negative velocity inlet (velocity outlet)?? Is it possible to do it by using FLUENT 6. I tried it with FLUENT 5 but when i changed the velocity direction to negative, the defined mass fraction was ignored. Can somebody suggest me a solution for this problem??? Thank you. From KKLAU |
June 14, 2004, 14:23 |
Re: Define mass fraction for -ve velocity inlet/ou
Well, composition is naturally propagated from inside of the computational domain to the outlet boundary - that's why you cannot specify outlet composition beforehand. It will be used only with backflow (intake of fresh fluid from the inlet). What are you trying to model by this BC - a membrane??
George |
Defining species mass fraction using a UDF | T81 | Fluent UDF and Scheme Programming | 3 | April 19, 2018 07:02 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
reversed flow at velocity inlet / mass flow inlet | ib | FLUENT | 1 | March 26, 2007 13:11 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 12:24 |
UDF FOR UNSTEADY TIME STEP | mayur | FLUENT | 3 | August 9, 2006 10:19 |
